Arnova ChildPad capacitive and resistive models ICS custom firmware with Google Play and root
t23
Forum Posts: 27
46
2012/07/31 - 02:57
No, you are indeed right, there is so far no official update for the capacitive CP. Apart from that, the 1GB firmware you can find elsewhere on this site runs pretty stable, except for the Calendar (now fixed thanks to bdejonck!) and Contacts issues.
You can always sideload Titanium Backup from http://matrixrewriter.com/android/ if it's not on Appslib.
Faffe
47
2012/08/02 - 22:12
Thanks for this, without the play store and especially the Youtube app this tablet would have wothless. As a fairly inexperienced Android user I find it amazing that anyone can sell an Android device that can't install apps from the Play store.
Thanks Received: 3170
48
2012/08/03 - 00:02
The reason for that is the device isn't certified by Google, currently as almost any other tablet based on the Rockchip platform.
This is slowly evolving as some devices such as the Archos 97 Carbon (Rockchip RK2918 based) are now CTS, and more should be in the future.
Dolby
Forum Posts: 64
49
2012/08/03 - 20:20
The childpad end the Arnova 7D G3 are allmost the same tablet or not?
I want also for my kids the google play store. Becourse the Applib isn't very good with the apps.
2x Archos Arnova 7D G3 tablets for my 2 sons.
But i have problems to get microsd working on de arnova 7D G3. Help please!
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
50
2012/08/03 - 21:52
The firmware we sent to you today has Google Play. The flashing method should be the same as for the ChildPad.
p-nico
51
2012/08/06 - 12:17
Thank you very much for the custom firmware, I installed it without issue  Laugh !!!
I have a question, where could we find the original firmware for the capacitive ChildPad ? I have to take back my Childpad to be repaired and I would like to put it as just "out of the box" ;-)
Thank you
Nicolas
Dolby
Forum Posts: 64
52
2012/08/06 - 15:24
I think you go to the Orginal web site http://www.arnovatech.com en select your Childpad for the standaard firmware.
b.breum
Forum Posts: 91
Thanks Received: 12
53
2012/08/06 - 15:55
that would be the case if the poster didnt have a capacitive childpad. The firmware on arnovatech.com is only for resistive (as they write) which will render his devise useless since he cant use the touch screen..
p-nico
54
2012/08/06 - 17:12
You'r right, the only firmware available is the resitive one......
t23
Forum Posts: 27
55
2012/08/06 - 17:18
Not entirely useless, if you can flash it once you can flash it twice. Or in other words, you won't brick it, you just have to start over.
But yeah, don't waste time flashing a resistive image onto a capacitive pad, it's just a waste of time and a gain of frustration.
You can actually do this on the 7b G2 but that's another story :)
b.breum
Forum Posts: 91
Thanks Received: 12
56
2012/08/07 - 12:11
Just had a closer look on the applibs thats supplied with it (im still waiting for the childpad to get "home" from germany).. seems like it has ES explorer. Wouldnt that mean that i can install the apps i already have on my phone if i just copy them to the childpad? Then i wouldnt have to unlock it to get neither youtube or the kids game that has filled up my phone :)
Offcourse an unlock is never ruled out ;) cause the 1 gb solution would be nice so more programs can be put in.
57
2012/08/07 - 12:28
Yes, as most Android devices, you can "sideload" applications (copy the APK file on the device and run it from a file explorer application). It works for most apps, that do not require some systems libraries and files (ex. Google Play Store).
b.breum
Forum Posts: 91
Thanks Received: 12
58
2012/08/07 - 12:49
Im in doubt with that last comment about google play store. does that mean that i can sideload that also?
Eitherway it seems like sideloading titaniumbackup as the first thing would be smart thing to do.
Then youtube (if thats possible to sideload, since i can see the apk in my rooted phone)
Again thanks for this great forum and the speedy answers!
59
2012/08/07 - 12:55
Sorry if I wasn't clear, I meant sideloading Google Play Store is just a bad idea, in the best case you'd get a half functioning store. To get a proper Play Store you'll need a custom firmware.
Sideloading most other apps, including Youtube should be no problem.
b.breum
Forum Posts: 91
Thanks Received: 12
60
2012/08/07 - 13:00
and again thank you for clearing that up so fast.
well googleplay wont be an issue, since then i got full control over the tablet, what gets installed  🙂 I just need NOT to make an account on appslib so he cant go fussing in there either ;-)
So without play a bit more work for me, more safety for my kids.
And yes i know that you can make market "safe" for kids - it was more in the line of him not buying apps ;-)
43 Guest(s)
Devices in use: Desktop (37), Phone (6)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
