Arnova ChildPad capacitive and resistive models ICS custom firmware with Google Play and root
sakis13sakis
136
2013/01/04 - 19:47
play to fifa 12 the custom filware and google play store?
MCMXCV
137
2013/01/27 - 15:37
Just installed the custom firmware. It all seemed to instal as it should but now my touchscreen doesn't work? Is there a reason for this? I followed the tut to the letter...
...also is there a way to change it back to the vanilla firmware or is it just a brick now?
Thanks Received: 264
robwilsonirl
139
2013/01/31 - 21:14
I've upgraded the firmware and all works okay except the speakers.  No sound through the speakers but headphones work okay.
Any ideas ? :(
awol74
140
2013/02/01 - 16:28
I've rooted the two childpads of my children to gain acces to the playstore, worked fine but....the childpad doesnt seem to recognize the sd-card it says its 'simulated' memory.
i cant move anything to the sd-card and therefore the amount of space is very little. i've googled and this seems a common problem....does anyone have a solution for this?
stevedee
Forum Posts: 19
141
2013/02/01 - 18:01
glemdring
142
2013/05/26 - 12:50
Hello everybody!
Can someone advise custom ROM for resistive model where Contacts and calendar are working?
Thx!
lutinsdu45
143
2014/04/10 - 01:37
Hello all
here is one I have trouble with my tablet ChildPad is common but which I really dry
after you install a firware containing the play store the tablet restarts and s is then devnue install a brick because my touch screen no longer responds . So I have searched all day on the forum to find help, but I block differente stage or offer to spend the tablet in flashing mode (if I 'm not mistaken c when it has a black screen with an android guy and lengthens a red exclamation point ) until I downloaded the ca rockchip and will ask you to install the device drivers that I recovered from rockchip batch tool, my computer detects the new device well but when I show him the source or take driver does nothing and when I press next it puts me in the end that is no huge peripheral na assistant .
J hope that I will be understood I 'm sorry to annoy but I am in tears in front of my computer completely helpless thank you in advance to you
86 Guest(s)
Devices in use: Desktop (72), Phone (14)
pippolon
jomama
biggfafa
himikus300483
CyberByte
printerr724
