Β Please donate to support OMA and CrewRKTablets firmware work, thank you !
We will probably make update with increased partition for /data soon.
Which size would you prefer ? 1 Gb, 1.5 Gb or 2 Gb ?
2012/07/01
No worries, you guys are doing great. I found another little quirk about the child pad. Apparently every time i reboot any apps or folders on the home screen get removed and its reset to the default folders. Anything you guys can look into.
So wishlist:
1.5gb install partition
Customizable Home screen
2012/07/03
Hi,Β
I would like to install the custom firmware on the childpad, but how can I get back if something fails? I have the childpad with capazitive display and did not find any original firmware for that.
And: Are the original apps still there in the custom firmware?Β
Β
Michael
First things first... GREAT JOB !
I do not want to put too much pressure on the shoulders of you developers but I have 1 small question. Maybe a stupid question. Is it possible to have google+ and google talk to work on this image? I tried to install the google+ via the play store but when selecting the account it always returned errors from the server. And google talk I took the apk from my SGS2 and copied it over and installed it fine. But when launching it, it stopped and closed.
Maybe I did something wrong?
2012/07/09
Thanks for the Play Store, it works perfectly.
One thing I did notice: it only works with existing accounts. If you want to create a new account from within, the Store crashes. But you can of course create a new account through the web without any problems.
Β
As said before, Google Talk would be really nice since it also has a camera.Β
2012/07/15
Good stuff! Without the firmware the tablet would be quite crappy π
Now, as someone completely new to Android, I've googled for a way to install apps on the sd card instead of the internal storage to circumvent the 512 MB limit. But nothing worked so far.
There seem to be two different ways
1) Using "Move to SC card" that is supported since Froyo
With ICS this seems to have gone, at least I don't find it on the childpad with the custom firmware
2) Using the ADB shell and setting "pm setInstallLocation 2"
This does not seem to have any effect at all
Does anyone know a way to install apps on the sd card or maybe move installed apps there?
Any help would be appreciated. π
The following users say thank you to brackmeister for this useful post:
arcomanMost Users Ever Online: 803
Currently Online: Azabatxe1
154 Guest(s)
Devices in use: Desktop (147), Phone (8)
jacksonrid
usdown
ibob64
