Archos/Arnova ChildPad review Part 1: Introduction
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/06/03 - 22:44
The longly awaited Arnova ChildPad (first known as Archos ChildPad) has finally started shipping in the USA. This tablet is developed with children in mind and will be available in capacitive and resistive versions and with or without the Alvin UI. This review covers the Alvin model for the EU, with 4GB of flash memory, resistive screen(no dual-touch on this one); though it shares many specifications with other ChildPads.
Image Enlarger
Arnova ChildPad video unboxing&preview
Arnova ChildPad specifications
Operating System Android 4.0.3 (Ice Cream Sandwich)
Linux Kernel Version: 3.0.8+
Build fingerprint: Android/rk29sdk/rk29sdk:4.0.3/IML74K/eng.root.20120503.144920:eng/opinions-on-teclast-p90hdst-keys
CPU single core Rockchip 2918 CPU running at 1 Ghz
Integrated GPU: Vivante Corporation GC800
Flash Storage Memory Capacity 4 GB
Speed: Read: 15195 kB/s Write: 6589 kB/s
System Memory 1024 Mb
Additional storage Micro SD slot (SDHC compatible)
Display 800x480 TFT LCD 7.0 inches
Resistive 1 point screen
Bluetooth No
Wifi 802.11 b/g/n
Gravity Sensor Yes
Camera 0.3Mp (front facing)
GPS No
HDMI No
Interfaces Micro USB host 2.0: Mass Storage Class (MSC)
MicroSD slot
Battery life Video playing test: 5 hours 15 minutes
check our Archos and Arnova battery tests page
Android Market / Google Play No (For children optimised Appslib application Marketplace)
Kickstand No
Dimensions 223 mm x 142 mm x 12.2 mm
Weight 342 g
Packaging
Packaging is a little bit different from the other Archos and Arnova products, you will find in the box:
- an Arnova ChildPad tablet
- an USB cable (micro USB format) for charging the tablet
- an USB cable (micro USB format) for transferring files
- 4 papers that include: Arnova ChildPad User Guide, Arnova ChildPad Quick-Start Guide, Alvin advertising paper and  Legal and Safety Notices
- a power charger with one power socket (depends on region, we got an European one), input 100-240V, outputs 5V 1.5A
Image Enlarger
Tablet Design
The ChildPad shares its design with the Arnova 7d G3, the only difference are the colors. While Arnova 7d G3 is just black, the ChildPad is painted in nice-looking white and blue colors. The tablet is made of matte plastic, which should not catch fingertips…
116 Guest(s)
2 Guest(s)
Devices in use: Desktop (97), Phone (16), Tablet (3)
Kosak0
mertenschrist
Erval
jhs456
s282
Gutts62
Topics: 6030
Members: 261571
