Archos 80 Xenon Custom rom
Custom rom for 80 Xenon
vibrocil
Forum Posts: 15
2013/12/12 - 00:13
Hellow there,
After a lot of trying I finally made a custom rom for the Android 80 Xenon.
It is based of the original rom found in this forum here and not android compiled from scratch :p
I removed a lot of standard software, only thing left is calculator, chrome, clock, system monitor, play store, contacts and messaging. I added ES File Explorer and Nova launcher instead of the default launcher. All the apk's are deodexed and root is added. On my device after a clean boot it uses around 230MB ram, but I've got already some other software installed on it... For the rest everything still works as normal and in my opinion, just that little bit faster :p Anyway, the link is on adFly, maybe I could make a buck with it :p
TIP: Always keep stock rom available before flashing... First boot might take a little bit longer than usual...
http://adf.ly/abyzS
Please let me know if there are problems or suggestions!
paolodenny
2013/12/20 - 08:42
hello,
i'd like to know which kind of android rom is your custom rom? 4.2 4.3?
and the easier way to install it.
if i install this rom may i come back to the original rom if i find it? and the way is the same or different
thank you in adance
vibrocil
Forum Posts: 15
2013/12/28 - 03:31
paolodenny said
hello,
thank you in adance
As I said it's based on the original rom, which means 4.1.2... Can be installed through clockworkmod, all info is available on this forum...
sengirb
2014/03/12 - 18:59
Hi thank you for your work
when i install it with cwm i get installation aborted
why?
vibrocil
Forum Posts: 15
2014/03/13 - 13:54
why?
Could you be more specific about the error? I assume at least there's an error number it shows...
Also, been a while since I made this one, will do another one soon as I don't have the files anymore I used for this one...
When does the error happen? Is it immediatly or does it do something first? Can you reboot after?
Gianni
2014/03/16 - 12:52
i'm unable to install it too.
In cwm (stock) the zip is going for 20% then say: istallation aborted.
I try to install cwm update but i foun problem. do u have suggestion?
vibrocil
Forum Posts: 15
2014/03/16 - 13:11
What do you mean by "cwm(stock)"? I hope Stock Rom with CWM installed, not the stock recovery...
As I said to previous poster... CWM does not normally just abort... There are error messages... Anyway, a new rom is on it's way, I've been busy with other stuff the last few days. I'll see if I can recreate the error and get back to you on that.
Gianni
2014/03/16 - 14:25
excuse me for my english.... i mean in base recovery mode, because i have problem whit installation of any type of cwm (arctools apk too) .
The tablet Is "like" blocked.
if anyone have a alternative method to update rom please tell me step by step.
Its the first time i have problem to install a alternative rom on android device!
vibrocil
Forum Posts: 15
2014/03/16 - 14:36
You're not going to be able to install a custom rom in base recovery mode... Only the official one...
I replied on another topic on how to install CWM on this device. In short: reboot in fastboot mode (poweron+vol down) Your device will indeed appear to be hanging, but you can use the fastboot application now from your pc. With fastboot you need to flash the cwm file also found in this forum and then you can reboot into CWM (poweron+volume up) Look around, the detailed instructions are in the same topic as to where the cwm file is... As an update I already started working on another rom, hardest part is already done, but you will also need cwm for this, so do that first...
Greetingz
EDIT: Topic with CWM image+info is @ http://www.arctablet.com/blog/forum/archos-97-xenon/archos-80-xenon-rootinfodevelopment/
The following users say thank you to vibrocil for this useful post:
Gianni
Gianni
2014/03/16 - 17:35
Ok . Installed it but is stopped on bootscreen "archos entertainment your way"
vibrocil
Forum Posts: 15
2014/03/16 - 17:58
How long did you wait?
Gianni
2014/03/16 - 19:53
1 hour or +....
vibrocil
Forum Posts: 15
2014/03/16 - 20:02
Gianni said
1 hour or +....
I'm uploading a temporary one I found between my old files... Just tested it myself...
Gianni
2014/03/16 - 20:10
where is it?
vibrocil
Forum Posts: 15
2014/03/16 - 20:12
Gianni said
where is it?
Still uploading...
160 Guest(s)
Devices in use: Desktop (153), Phone (7)
jacksonrid
usdown
ibob64
kawi
