i have a Carbon and a Nokia N97. The Carbon is rooted (kasty-arc97carbon-40-042-2G.zip). Now i want to tether with my N97. At the N97 is running Joiku, and my Laptop find the N97, but the Carbon find not the adhoc wifi.
What i have to do? (i'm a newbie for tablet pc). And it is equal for me, if it's work with wifi or with USB-Cable.
I need the easy way to work, if possible step by step.
Thank you.
Torsten
You'll need to enable WiFI ADHOC support on your device, you can have a look here:
I don't know if it works or not on the ARCHOS 97 Carbon.
That's great, thanks for your feedback Torsten !
Currently Online: sadako11
71 Guest(s)
Devices in use: Desktop (67), Phone (5)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
