Can you explain more about this issue, on my tablet is not ocurring.
Did you flashed this version and still had the problem ?
2013/01/03
No this is present on the stock rom provided with the tablet. It only occurs when off white colours are used. I immediately noticed it on the Adobe app "Sketchbook Pro" as the default background colour flickered like crazy. When I filled the screen with pure white it resolved. Maybe it's a hardware limitation of the screen.... i.e. dithering to achieve colour?
Can i test only with the free app ?
Edit:
Found it, yes i noticed this on grays backgrounds actually, not white, it looks like the refresh rate is on 30 hz and that`s why you see the flickering.
It can be related to the both hardware/software side.
I already forwarded some problems to Archos with the YouTube app, which buffers only maximum 1 minute, and after that it stops, you need to skip 5 seconds of the video to get it working again.
Also a problem with the Wi-Fi when the device comes up from stand by, you cannot connect to any wi fi, unless you re-enable the Wi-Fi function, and sometimes you need to restart the tablet because not even the Wi-Fi will work.
150 Guest(s)
Devices in use: Desktop (143), Phone (7)
