2016/10/08
Hello to all forum users
I own an Archos 80 Cobalt (model number: TCK8212, version 3.0.8 +, Kernel Vers. Android 4.0.4); After the system update downloaded from Archos.com, on reboot the device has the touchscreen reversed — that is, if I touch the right side of the screen will start the features found on the left side of the screen. Now, I tried everything including recalibration via wizard, but the problem persists. the build is version 20130202, but I remember perfectly that one installed above began with "2014..."; on the Archos page however is not present. I also tried the build custom present in the forum but nothing.
Can you help me to fix it, or tell me to limit what was the present version (2014...etc) before I upgraded?
UPDATE:I found a screenshot of the firmware that was there before the upgrade was wrong,but I can't find it on the network can anyone help me please?
Hm, never noticed a 2014 firmware. Pls check with the Archos support.
97 Guest(s)
Devices in use: Desktop (88), Phone (9)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
