Here is a rooted custom firmware based on latest ARCHOS 80 Cobalt update published by ARCHOS (20130329)
Build information
Linux Kernel: Linux version 3.0.8+ (lfzhou@midcs-desktop) (gcc version 4.4.0 (GCC) ) #9 SMP PREEMPT Sat Feb 2 10:10:33 CST 2013
Android build: A825KD-user 4.0.4 IMM76D 20130202.162053 release-keys
Download: kasty-cobalt80-40-20130202-rooted.zip
To be flashed with Rockchip Batch Tool, use Restore button.
This custom firmware was tested and confirmed to work, thanks to globula_neagra.
2013/05/20
Hi I m french.
I try to root my cobalt but it is impossible.
My archos and my computer don't communicate.
My pilote for archos is in my computer: pilote de volume sysyteme wpd!!!
also i can't root my tablett.
Please help me!!!
I have try all the procedure with root archos and another but i think it is a problem of pilote
This firmware has been tested by me and works fine.
I got the tablet in flashing move via adb with the command
adb reboot bootloader
Installed the rockchip drivers
Opened the rockchip flashing tool and selected the firmware and used the RESTORE option to flash.
If you still don`t manage to flash your tablet you can refer to this
http://www.arctablet.com/blog/forum/archos-arnova-general/flashingunbrick-project/
Have you read the tutorial ?
Try to use another usb cable, and the usb port from the back of the pc unit
I did not considered this option as for me is basics
X86 = windows 32 Bit
X64_ 64 bit
62 Guest(s)
Devices in use: Desktop (57), Phone (5)
hans41
rickybk
soniya07
ironmangitar
