Archos 7c flash storage unavailable...
leevex
2011/11/11 - 04:38
I did some formatting but then after the flash storage of my A7c can't be read by my Windows pc... Any suggestions to get this back to normal again...
It also shows on my notifications that "internal flash storage safe to remove".
Usb gets connected butit wont connect to my pc...
I tried resetting but to no avail...Please help thanks.. :)
wjrg
2011/11/11 - 10:31
how/what u have formatted? somtimes it happens to me, I just reboot my PC, and it connects again. Can u connect ur A7c to another PC, check if same error, we want to figure out if it is a PC error or A7c error first.
I know nothing .. new in Adroid world
leevex
2011/11/11 - 14:05
I just formatted my sd card then after that, it isn't recognized by my pc anymore... it' like my flash storage is unmounted/ uninstalled from my archos
i don't think it's a pc error 'cause my other devices would connect to my pc...
hope you can help.. thanks
wjrg
2011/11/12 - 11:04
I never formatted my internal storage before, not sure if it is safe to do it. Guess u wanted to wipe out everything, would u mind to reinstall ur update.img file again by using RKBATCHUPGRADE? just to start thing from scratch. Oh, are u using original A7c ROM or custom ROM? Froyo ROM u have to manually turn on USB storage via notification.
Thanks Received: 3169
2011/11/12 - 11:27
As mentionned by wjrg, Froyo firmware need to manually mount your drives thru USB so they can be seen on the remote computer.
You can see the details of the procedure in the "Mounting Arnova 10 on your PC / turning ON USB Storage" area from this article:
/blog/featured/arnova-10-custom-android-2-2-froyo-firmware-android-market-root-kasty/
Currently Online: Duceman, bogdushok
112 Guest(s)
Devices in use: Desktop (98), Phone (16)
bogdushok
Torn
zombo
васа
kindr
TOFIK
Topics: 6010
Members: 260678
