Alarm ringing too late
satura
2015/09/15 - 09:19
My use case: Set alarm in the evening using AlarmDroid, switch on plane mode and diamond shall wake me in the morning. Unfortunately sometimes alarm starts not at the set time but some minutes later (15 and 13 minutes the last two times).
Anybody else experiencing such problems or even has a solution?
In the AlarmDroid forum they say that sometimes battery saving options may prevent alarms from activating on time but I do not have a special app for that and I am not aware of such options in the Diamond settings.
BTW phone is rooted but problems already occured before rooting.
satura
2015/10/23 - 16:49
I found the following solution to my problem: I installed the app "Wake Lock - PowerManager" (eu.thedarken.wl). In the evening I start the app and set a PARTIAL_WAKE_LOCK (level 4) and in the morning I set it back to NO_LOCK (level 0). Every time I set the wake lock the alarm rang at the correct time and surprisingly it doesn't have any negative effect on the battery.
80 Guest(s)
Devices in use: Desktop (78), Phone (2)
djwood1014
4ipolino
thomashansmuller11
abro
Yoyoo
sfaris
