Google Sync, root, custom ROMs etc.
Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0Topic Rating: 0 Topic Rating: 0 (0 votes)
2012/01/31
22:07
Hi everyone:
I am new here, but I think this may be the right forum to ask, as I am not getting any help in XDA.
I just bought an Archos 35 Smart Home Phone and I noticed it has no Google sync, I tryed ArcTools, but it kinda only half worked. I can add Google accounts now, but I can't sync them, and I was able to download gmail, but since it doesnt sync, I can't get e-mail.
I would also like to potentially root/install custom ROMs, can someone help me with where to start, I cant find any info.
Thanks!
2012/01/31
22:12
Forum Posts: 3704
Thanks Received: 1043
JMI Pulse 10
If you followed ArcTools install procedure, you should have a functionning Android Market, together with a working mail sync (you'll need to download Gmail). ArcTools hasn't been tested yet with the Smart Home Phone but should work as it is a pure Gen8 device. I just got my hands on this device, so I should be able to double check soon, and correct if there are any issues.
There is no working root for Gen8 devices currently.
The best custom firmware option is probably Urukdroid, but I don't think it would work on the 35 SHP and if it does you'd probably loose the DECT functionnality.
2012/01/31
22:24
Ok, cool, thanks.
I think there may be issues related to the SHP with the ArcTools app. I have tried all of the available packages, I get issues that are either, little to no apps installing up to a best case scenario of only some things syncing (contacts/calender)
2012/01/31
22:45
Forum Posts: 3704
JMI Pulse 10
If you are missing apps, you may want to try the Market Fix
I'll have a look at these Arctools issues when I check the 35 SHP, will keep you posted.
2012/01/31
23:24
Yeah, from what I can tell, gmail sync doesn't work, go into gmail, confirm account is added, accounts and sync now says sync is on, but it doesn't list gmail as an option…
2012/01/31
23:34
Spoke too soon, apparently, this time (after I did a reset Android), everything looked as though it was going the same, but all of the sudden, gmail was listed under sync, and it is working… Looks like maybe after adding th google account you have to wait 10-15 minutes for the services to appear…?
Any way of getting the unsupported apps to work? (like google books) do I have to edit my build.prop file?
2012/02/01
18:24
Forum Posts: 3704
JMI Pulse 10
You won't be able to modify system files (that includes build.prop) without root on the device. If the Market fix doesn't work, you'll have to get the application from another tablet/phone and side loading it on the machine. (just copy the APK file and execute it from the file manager)
2013/02/09
17:39
I want to install SDE in Archos 35 smart home phone (A35DE).
Someone try with Archos Gen8 SDE ?
And after the multiboot AOS … and CM7…
I try to root with archangel 1 and 2 but is not OK
I try to root with unlockroot 3.1 bt is not OK
I try  to root with adb but I've not right to install "su" in /system/xbin
2013/02/09
22:46
Forum Posts: 3704
JMI Pulse 10
The Archos 35 Smart Home Phone is based on the 35 IT, which is a Gen8 device, so SDE should work on it.
Have you tried [[** please register to see this link **]] ? If I remember right, this firmware should come rooted by default.
2013/02/10
02:02
It's because Archos write "SDE firmware for ARCHOS Generation 8 devices:
(ARCHOS 101, 70, 43, 32, 28 internet tablet)" and not specify the magic number "35"
I would not break my phone with a no good firmware :-)
2013/02/13
18:39
the Archos SDE firmware Generation 8 devices is not good
my phone is dead :-(
green led light when i press the power
green led flash with usb cable
2013/04/18
00:42
I have exactly the same problem
Have you figured out how to fix it?
2013/04/18
07:45
No, I dont find how to unbrick the phone
I try to boot with SD but …
The Archos SDE is very no good  !!!!
Most Users Ever Online: 646
Currently Online: wheresjc, icqcorsair, bubbaho, Nath4n, mintom, xmensamac, baumy1980, jayell337, cjs302turtle, patrickz, Chris_W, vlucia, adno812, JWangPapar, bz438, spiderwaui, vintae5262, cappybob, akfaris, davylawlor, dub01, ronnel0918, crossfader, adamman
109 Guest(s)
admin: 3704
globula_neagra: 1886
Guest Posters: 36
Members: 75130
Forums: 123
Topics: 2819
Moderators: HaroldG (117), globula_neagra (1886), exelletor (344)
Administrators: admin (3704)
