Archos 101 XS (Gen 10) review | Part 2: tablet design
Thanks Received: 3170
2012/08/23 - 13:32
Archos 101 XS has managed to pack a new design and deliver a very thin tablet. Both faces of the device are made of white plastic mixed with metal enclosures light gray colored.
Compared to previous Archos models, it seems there has been a lot of efforts in the tablet build quality, as the pieces are now better adjusted, the whole device seem quite solid, the material feel quite good and does not catch fingerprints.
Image Enlarger
Image Enlarger
This video gives a quick overview of the Archos 101 XS tablet and coverboard design.
Connectors
On the left, you can see the 1 Mpixels frontal camera and a tiny hole which should to be dedicated to the microphone. The tablet side holds the connectors, from top to bottom:
- micro SD card connector (SDXC compatible)
- micro USB connector (host capable)
- headphone connector connector, usual 3.5 mm mini-jack format
- the HDMI connector (mini HDMI format, aka HDMI type c connector)
Image Enlarger
On the tablet's right side: power and volume (+/-) buttons.
Image Enlarger
On the bottom side of the tablet: the keyboard/cover connector and 2 magnets to hold it in place.…
80 Guest(s)
Devices in use: Desktop (64), Phone (13), Tablet (3)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
