CS918S Quad Core Android 4.2.2 TV Box Mini PC A31S HDMI Wifi Bluetooth Camera 16gb
Android TV Box Allwinner A31S
Dvalin21
Midwest City, OK
Forum Posts: 41
Thanks Received: 10
2014/03/20 - 21:11
http://dealsprime.com/cs918s-quad-core-tv-box.html
pplication Process Model Number: CS918S
CPU  Quad-Core  A31 ALLwinner
Memory 2GB SAMSUNG
FLASH 16GB HY
HW WIFI and Blue-tooth WiFi 802.11b/g/n,wireless internet connecting ,Blue-tooth4.0 RELTEK8723
ETHERNET RJ45
REMOTE CONTROL Transmission:2.4G wireless remote control
USB USB HOST*4
POWER POWER OFF/ON * 1
SD TF  CARD SLOT*1
OPTICAL OPITACL OUTPUT * 1
R/L(AUDIO)+CVBS R/L(AUDIO)+CVBS (AV)
IR IR module( extendable to support)
Camera  500W
MIC Built-in
HDMI HDMI OUTPUT*1
    IE,IM,Mailbox,Video/Audio player,4K PLAYER
Application  Picture viewer, Text reader & Games
On-line Videa/Audio player
Video •UHD H.264 2160p video decoding
•Multi-format FHD video decoding, including Mpeg1/2, Mpeg4 SP/ASP GMC, H.263, H.264,etc.
•H.264 High Profile 1080p@30fps or 720p@60fps encoding
•3840x1080@30fps 3D decoding, BD/SBS/TAB/FP supported
•3840x1080@30fps 3D encoding
•Complies with RTSP, HTTP, HLS, RTMP, MMS streaming media protocols
Audio •Two sets of I2S/PCM interfaces for Baseband and Bluetooth
•Two integrated differential analog MIC for headset and phone
•Integrated digital MIC interface
•Dedicated headphone/speaker/receiver outputs
•Two-channel audio ADC with 96dBA SNR
•Two-channel audio DAC with 100dBA SNR
Screen Size No
Screen Type No
DDR3 Capacity 2GB
CPU Frequency No
Back Camera No
3G No
HDMI Yes
Latest Official Rom Download
http://blog.geekbuying.com/index.php/2014/03/08/rom-download-new-stock-firmware-for-cs918s-allwinner-a31s-quad-core-tv-box-built-in-xbmcseems-support-hardware-decoding/#.UytG3k_IZyV
It would be awesome if someone could help with this.  Found Imgrepacker for Allwinner CPU roms, but I have no clue what to do or where to go after that point.  Where as most recovery files come in .img format,  when using the tool it comes out as .fex
 PS:  I've been able to decompile the ROM.  I've attached the decompile files for the ROM and the tool that I used to decompile it. (No I'm not a dev, just resourceful) It would be a big help as my attemps has failed to create a custom recovery CWM or TWRP. Thanks.
Dvalin21
Midwest City, OK
Forum Posts: 41
Thanks Received: 10
2014/06/02 - 19:15
So I have figured out on my own a lot of the things needed to modd this rom.  I've created custom zip files to create custom roms.  I also have a custom CWM recovery, however the only problem that I have is I can't find the script.bin file that is suppose to be in the bootloader.fex, but is not located there.  Anyone that may have any advice I would appreciate it.  Here is a link of the rom https://mega.co.nz/#!jxpyWLqZ!s3EJx40-qU64TLpXztEH7oPLOEWX-N3MNd0e5N3Arvc
78 Guest(s)
Devices in use: Desktop (55), Phone (22), Tablet (1)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
